Good link for APEX. Don't forget about the "big 3". Even for a stock alternator. So many cars with wimpy inadequate wiring. New cars included, even high performance models.
350 amps in a Honda CR-V? Tell us more. Are you running a food truck, a roach coach, or............... (LOL).
About Our Alternators
Important Information If you attempt to run a new high amperage alternator with a stock battery, this could cause voltage drop which will negatively impact the amount of voltage delivered by the al…apexhighoutputalternators.com
I upgraded the vehicles 12 V battery from 51R to 24F.Good link for APEX. Don't forget about the "big 3". Even for a stock alternator. So many cars with wimpy inadequate wiring. New cars included, even high performance models.
Had a stereo shop do the big 3 upgrade with 0 GA. Also had them put in a 350 Amp fuse and after the fuse a run of 0 GA. that goes through the firewall behind the glovebox runs unseen by front passengers door and comes out under the back of the front passengers seat terminating with a high current quick connect that I later sprayed Avaition grade Corrosion X on to prevent any degrading of the connections over time and wrapped it in plastic bags.
I bought an extremely reliable very pure 2200 Watt / 4400 Watt peak sine-wave 12 VDC to 120 VAC inverter made by Mean-Well with mating quick connect and 0 GA. wire on the input. Stereo shop added 2 strips of velcro to the bottom of the inverter so it sticks to the floor carpet in front of the back passengers side seat, and a hole with a cover added in that area allows a 12 GA. 100 ft outdoor rated extension cord to come in from under the vehicle.
At idle this system has enough power to run my houses forced air gas furnace (50% on duty cycle on very cold days and 3.5 Amps peak draw), the fridge (about 2 Amps peak during automatic defrost), a few lights (led's) and a TV, for over 45 hours on a full tank of gas. I try to keep it near full in the winter, and make sure it is full before each major snowstorm.
The work by the stereo shop cost me $1000.00 and the high Reliability very pure sinewave inverter that has output damage protection cost around $819.00.
With the battery size upgrade including bigger tray and cover (new) for a 2013 Odyssey (drops in easily), and the alternator, shorter serpentine belt (had to buy 2 the first one I bought was too short to get it to go on the vehicle) the entire upgrade ran me about $2500.00
When I realized that the engine computer will maintain idle even with added loads on the alternator I knew this project would work, and it does.
I know what fuse to remove to disable the vehicle from being able to be driven away when left running, and I have a solar powered remote intrusion alarm (normally used as a driveway intruder alarm) that I set in the vehicle when I'm not in it, and a club lock.
Removing the fuse sets a code, but I can clear that with my blue-driver.
