Here is my first post sorry if it doesn't look correct. I just bought this 2012 GMC Terrain, FWD, 4 cyl with a little over 40,000 miles. No know engine problems but I wanted to do an UOA on the engine. I did this through our local Caterpillar dealer who does the simple SOS report for only $10 which I thought was cheap. In the future I will use Blackstone. I have no idea on what oil was used it did come from the GM dealer so who knows. I have a daily commute for about 100 miles which is all highway travel. I average 52 mph on a tank of fuel which is fairly flat travel...central WI. The OLM was updated right before I bought the car and it now reads a max of 5,000 miles per OCI. I changed the oil the other day and just went to Mobil 1 5w30 synthetic with a purolator filter. I still have the power train warranty until 100,000 miles, but with my conditions 5,000 seams low for the OCI. Let me know what you think.
Code:
Cu Fe Cr Al Pb Sn Si Na K Mo Ca Mg Zn P
3 26 1 4 0 0 9 14 2 61 2004 23 825 729
ST OXI NIT SUL W A F V100
0 25 18 32 N N N 7.4
Key:
Ag = Silver, Al = Aluminum, B = Boron, Ca = Calcium, Cr = Chromium, Cu = Copper, Fe = Iron, P = Phosphorus, K = Potassium, Mg = Magnesium, Mo = Molybdenum, Na = Sodium,
Ni = Nickel, Pb = Lead, Si = Silicon, Sn = Tin, V = Vanadium, Zn = Zinc, A = Antifreeze, F = Fuel, W = Water, P = Positive, N = Negative, T = Trace, E = Excessive,
NIT = Nitration, OXI = Oxidation, ST = Soot, SUL = Sulfation,
ISO = ISO Rating, PFC = Percent Fuel Content, PQI = Particle Quantifying index , NaW = Salt Water, FL Pt = Flash Point, TAN = Total Acid Number, TBN = Total Base Number,
H2O = Karl Fisher result, V100 = Viscosity@100C, V40 = Viscosity@40C
Code:
Key:
