Here is the second go round with draining/filling the PTU/Transfer Case in my 2012 Ford Fusion Sport AWD. The results of the initial drain can be found HERE: http://www.bobistheoilguy.com/forums/ubb...PTU#Post3257204
As you can see the most notable difference is the decrease in iron (a good thing). I expected a more significant change and blackstone did too. There are no noticable operational problems with the powertrain in my car.. Any thoughts would be appreciated!
Most current UOA Report :
https://flic.kr/p/nY7pkR
Code:
Comments: We gave this transfer case the benefit of the doubt last time, even with quite a bit of metal present, but things didnt improve nearly as much as we were hoping for. Aluminum and iron are lower, but its likely that the shorter oil run had a lot more to do with that than mechanical parts that are actually wearing better. Silicon could show dirt, though that shouldnt really enter a closed sstem. Insolubles are quite high, showing a lot of solids from heat, use, and oxidation. The TAN is 3.7, showing some acidity. Any operational issues with this TC? OIL Amsoil Severe Gear 75W140 MILES IN USE 10,000 MILES 54,400 SAMPLE TAKEN 05/02/14 ALUMINUM 443 CHROMIUM 3 IRON 356 COPPER 17 LEAD 1 TIN 1 MOLYBDENUM 1 NICKEL 1 MANGANESE 3 SILVER 0 TITANIUM 0 POTASSIUM 3 BORON 50 SILICON 362 SODIUM 3 CALCIUM 1 MAGNESIUM 2 PHOSPHORUS 513 ZINC 9 BARIUM 0 SUS VIS 210ºF 112.0 cSt @ 100ºC 23.14 FLASHPOINT ºF 435 FUEL% - ANTIFREEZE% - WATER 0 INSOLUBLES 1.0 TBN - TAN 3.7
