Originally Posted By: schuylkill
I have 143K on my Elantra and there is now a slight tapping noise I hear at idle after it is hot which I never noticed before. This is not a DI engine. Does anyone have familiarity with these engines? I haven't found valve adjustment on a maintenance schedule, is this correct?
http://www.hyundainews.com/us/en/media/pressreleases/33812
Under the hood, the Elantra is powered by an all-new 1.8-liter Nu four-cylinder engine with 148 horsepower and 131 lb-ft of torque (145 horsepower and 130 lb-ft of torque for Elantra PZEV). Thanks to advanced clean engine technology, most Elantras sold in California, Oregon and several Northeast states are certified as Partial Zero Emission Vehicles (PZEV) by the EPA. The PZEV Elantra is as clean as many hybrid electric vehicles. The PZEV Elantra helps Hyundai meet its environmental commitments. Outside of these “green” states, the Elantra is available as an Ultra Low Emission Vehicle (ULEV).
Key Engine Components
• Aluminum block and head
• Dual Continuously Variable Valve Timing (D-CVVT)
• Variable Induction System (VIS)
Roller swing arm and Hydraulic Lash Adjusters (HLA)
• Electronic throttle control
• Offset crankshaft
The Nu engine features an aluminum block with a cast iron cylinder liner, cylinder head and crank. This unique configuration results in a block that is 30 percent lighter than an iron block, shedding more than 74 pounds off the entire engine weight, while still providing comparable strength.
The 1.8-liter Nu also offers Dual Continuously Variable Valve Timing (D-CVVT) camshafts and hydraulic engine mounts for optimum power, efficiency and refinement. Using CVVT on both camshafts has several advantages when compared with using it just on the intake camshaft including, a two percent improvement in performance (increased volumetric efficiency), two percent improvement in fuel economy (reduced pumping loss) and a 30 percent reduction in hydrocarbon emissions.
In the valvetrain, roller swing arms and hydraulic lash adjusters reduce valve driven friction to improve fuel economy one percent compared with direct valve driving. The Nu engine also features a maintenance-free silent timing chain system to enhance durability and improve Noise Vibration and Harshness (NVH).
The application of a plastic two-stage Variable Intake System (VIS) versus aluminum, enables switching between long and short intake manifolds, resulting in a four percent improvement in performance, a 15 percent reduction in cost and a 30 percent reduction in weight.
Another tool Hyundai engineers have incorporated into Elantra is an electronic throttle control. The electronic throttle control replaces the conventional cable and mechanical linkage with fast responding electronics. This system accurately controls air intake and engine torque, improving drivability, response and fuel economy.
The Elantra also features double-pipe plumbing (internal heat exchanger) to improve cabin cooling performance, while minimizing the capacity of the compressor to further reduce fuel consumption. An external controlled variable compressor is also used to improve fuel efficiency.
The Nu four-cylinder engine also has an offset crankshaft design that reduces friction between the piston and cylinder wall for a one percent improvement in fuel economy.
