2012 Buick LaCrosse 6T70 30k mi OCI Amsoil Signature Series
Buffalo, NY
The filter isn’t serviceable on this transmission without dropping it
When was the first time the fluid was changed in this unit?
I assume this is Amsoil ATL which has a starting viscosity of 6.3 cSt so it show the tranny is shearing the fluid somewhat.
Insolubles with manganese usually indicated wet clutch-pack wear.
Yes it is ATL. The entire fluid change history is on the report. This is the first time that I didn’t do a 3x drain and fill. Only ever sampled the first drain every time. This time I only did 1 drain and fill. Was planning on every 20k repeating the process
Well, what I meant was, was the first time the fluid was changed was it at 94,000 miles??
not OP, but seems to be.
