2011 Hyundai Sonata sudden siezure
North Carolina
I would pull the spark plugs and see if it turns over. then loosen the accessory belt and see if you can turn the engine over by hand with a wrench.
another Todd
Lakeside CA and Lake Havasu City AZ
After doing some research, apparently 2011 was the first year of Hyundai's new Theda direct injection gas engine. Now, after a few years they are becoming known as sludgers, prone to sudden and catastrophic engine failure/seizure. Hyundai is apparently denying as many warrantee claims as possible citing sludge due to improper maintenance, if the owner cannot prove that all oil changes were done and the proper oil and filters were used for each one. Looks like a big problem for owners.
Murfreesboro, TN
First something doesn't add up with the story... so i think we are missing something. Next, the alternator pulley is shaped funny due to some kind of design where the alternator does most of it's power generation when the vehicle is not accelerating, according to what i've been told. The starter in these vehicles has a known achilles heel where a plastic fork that deploys the pinion gear fails often and it's possible that this could be stuck engaged? Vehicle carries a timing chain. I am not aware of any sludge issues with this motor. One would think that if it had known issues they would have revised the design by now as the 2.4L Theta is the workhorse of most of the lineup and has been that way for quite a few years now.
another Todd
Starter being stuck engaged is one of the possibilities. Looks like the intake manifold has to come off to get at it. Just type in "2011 hyundai sonata engine failure" in your search bar, many sites will come up including below. You might want to inspect your Sonata for sludge to be safe. Just saying. 2011 Hyundai Sonata Engine Failure – Class Action ... www.chimicles.com/2011-hyundai-sonata-engine-failure... Cached Chimicles & Tikellis is investigating a proposed class action lawsuit against Hyundai for alleged premature engine failure in certain 2011 Hyundai Sonata vehicles.
VA
Originally Posted By: 285south
Change all the fluids (steering, brake, tranny, coolant) and replace the belts.
If only all of our problems could be solved this easily...
Nowhere NM
Nothing judgmental about this crowd is there. Sounds like you have a decent plan for trouble shooting, press on. Smoky
TX
Theta II. Has clutch on alternator pulley. Check for oil leaks around back of oil pan.
Canada
Originally Posted By: Propflux01
Please keep us updated on this, we are interested on what has happened.
+1 I sold the MIL on a 2011 Sonata. I'd sure like to know what caused this problem so she doesn't experience the same problems with hers!
another Todd
Sounds like more to the story is being untold. Wonder if car was being raced?
I think we have a winner !!
Who races a stock 4 cylinder Hyundai Sonata with 130K miles on it? I suspect there is more to the story, but I doubt it was being raced. I'll know in a few hours and let you all know.
Central Arkansastan
Teenagers and Son-in-Law's...
NC
Broken engine mount leading to collateral damage I.e. Belts, hoses, throttle cable, etc? Even if he slammed the gas down along with brake or revved the engine accidentally the car should have a rev limiter on it.
another Todd
Does not appear to have any broken motor mounts or leaks or anything else wrong externally. The engine is seized up tight. Removed the serpentine belt and cannot turn the crank with a wrench. He did admit to adding 1.5 quarts after the fact, and it is 3/4 quart low now so it was over two quarts low when this happened. We did not remove the starter so there is a very slight chance that it could be jammed into the flywheel and seized, thereby preventing engine rotation, but I am not holding my breath on that. I did look in the oil fill hole and everything I could see with the flashlight was VERY clean. The poor kid is now exploring his options, none of which are good. Thanks for all the replies.
dishdude
$100 Site Donor 2023
Phoenix
Now that's just weird! That explains the burning smell as the starter was trying to turn over a seized engine. Must be the timing chain...
California
wow - I'm driving the 2010 2.4L (75k now) and so far no issues. Wonder what's different on the 2011 2.4 and why Sonata - what about others using the same engine. Maybe mine is known for same issues - haven't checked into it....yet
Central Arkansastan
Maybe since car had less than half it's oil in the crankcase (at least 2 1/4 quarts low), that it's 5000RPM wind up at about the same time the brakes were applied hard caused what little oil that remained to slosh away from the pickup thereby starving engine and causing seizure?
