2011 GMC HD oil help
Washington State
I have a 2011 GMC 2500 HD pickup with a gas engine and it is getting time to get my first oil change. Wanted some help in picking either synthetic oil or a multi grade oil, or whatever you guys suggest.
Thank you in advance.
You have a HD pick up how do you tow? There is plenty of people just using their OLM and a conventional 5w30 and changing their oil with about 5-15% oil life left. Your 6.0 is a very good engine.
For warranty purposes make sure it says "dexos" on the bottle somewhere-use that as a search term, you'll see a few synthetic offerings (Mobil 1 & Pennzoil Platinum come to mind). And,
Don't tow anything. Will maybe haul some oil drums for my business, but won't be towing a boat or anything.
Kerry, my folks just bought a 2011 Chevrolet 2500HD w/ 6.0.
I'm about to do the same and change the oil.
The brand that caught my eye, according to specs was Kendall GT-1 5/30.
3.2 HTHS- pretty good for a 5w30
It is a synthetic/ dino blend
(And it has liquid titanium for an additive, if marketing floats your boat)
If you are in SW Washington, it's $1.99 a quart at Cost Less Auto Parts.
But when it comes down to it, any and all API SN 5w30's are great oils. So if you have a bias for a brand, go with it.
Welcome to BITOG!
Welcome to BITOG.
Presuming you're going to follow the OLM, then any quality oil meeting the OEM specs will do quite well. And the OLM is a fairly accurate way to track your oil change interval (OCI).
The 6.0L gasser is a great engine, and will do well with any brand of properly-spec'd oil. I would suggest that you don't overthink this, or you'll drive yourself nutty.
There is no "best" oil for all things or situations; but there are plenty of better choices that you can take comfort in using.
Oh, something I forgot. Being the usuall member of BITOG, I poured through the owner's manual of the Chevy HD, nothing was mentioned of Dexos? I was really surprised? Are HD vehicles with elevated gross weight excluded from GM's Dexos requirement? I could have missed it (the owners manual was about 600 pages) Just wondering... sorry to hijack!
Follow the olm until it tells you to "Change Oil", use a oil quality oil, and the engine will outlast the chassis.
We have had excellent service in our 6.0 trucks. Knock on wood, they have almost maintenance free except for a water pump and normal maintenance. I bet I still have 40-50% brakes left at 248 k miles on my daily work truck. My shop neighbor has the same truck and had same good service/luck as well.
Service the transmission, assuming you have a 4l80e, as well around 5k, then every 50k(filter every 100k) and it will provide very long service as well. I always used Mobil 1 ATF but have switched to Maxlife Dex/Merc because of the Dex vi requirement.
I have also always run an over sized oil filter, though many feel not necessary, either a M1 206 or Purolator Pure One PL25288. The Purolators are about half as much.
Ive also run a K&N air filter since about 100 miles. Not for performance but I like the idea of a serviceable filter to cut maintenance costs.
Big thumbs up for the 6.0. 145k hard miles on a 99 and still rollin along. I really drool over the '11s.
I was looking at the GMC site helping a buddy look for a new truck - GM has like 6 different gas engine offerings now!
I would look at Mobil 1 Avanced Fuel Economy oils, running them in all our gassers with great success on MPG.
I run Mobil 1 Turbo Diesel Truck engine oil and the Mobil 1 oil filter in my 2007.5 GMC 2500HD with the Duramax diesel engine.
Enjoy your 2011, lots of improvements under that truck that are not under mine!
