2011 BMW 335xi 6000mi M1 0w-40 -potassium again-
MA
I was worried about iron again, but I had a bit more Potassium this time. I'm thinking (hoping) it's the oil filter housing gasket allowing cross contamination which is common on these engines. I ordered up a new gasket and will replace this weekend.
Thread to last report is HERE
Code:
We're starting to see just a little more potassium in the oil. Normally we wouldn't make much out of the fact
that an element increased by 2 ppm. But since the element we're talking about is potassium and potassium can be a
sign of coolant, we have to at least mention it. It sure doesn't look like a problem, with wear levels reading just as good
as usual (and better than average). If potassium shows coolant, it's such a slight leak that neither you nor a mechanic
would see it. The TBN is strong, so try going back to 7,000 miles next time and we'll monitor it for you.
MAKE/MODEL: BMW 3.0L (N55) I-6 Turbo
OIL M1 0w-40 BMW 5w30 M1 0w-40 BMW 5w30
MILES IN USE 6000 7630 5520 5150
MILES 56283 50284 40660 35140
SAMPLE TAKEN 10/12/2015 3/31/2015 5/1/2014 11/16/2013
ALUMINUM 8 19 6 8
CHROMIUM 1 1 1 1
IRON 30 50 24 21
COPPER 4 6 3 3
LEAD 0 0 0 1
TIN 2 0 0 3
MOLYBDENUM 102 151 104 140
NICKEL 1 1 1 0
MANGANESE 2 3 1 1
SILVER 1 0 0 0
TITANIUM 0 0 0 0
POTASSIUM 16 14 2 2
BORON 136 75 151 61
SILICON 4 6 4 3
SODIUM 7 9 3 6
CALCIUM 3068 2397 3239 2321
MAGNESIUM 21 18 19 17
PHOSPHORUS 898 935 989 850
ZINC 1150 1112 1176 976
BARIUM 0 0 0 0
SUS VIS 210コF 70.2 63.2 68.5 64.4
cSt @ 212コF 13.01 11.12 12.56 11.44
FLASHPOINT コF 390 395 415 420
Fuel
Antifreeze ? 0 0 0
WATER 0 0 0 0
INSOLUBLES 0.2 0.3 0.2 0.4
TBN 5.6 3.7 5.6 5.3
Originally Posted By: DeepFriar
No arguing with that. M1 OW40 gets the job done!
That BMW 5W-30 got the job done too.
It did, and both oils held up fine. The only nitpick one could make would be the Fe and Al rate per 1K miles being higher with the thinner 5w-30 BMW oil:
Fe:
1st UOA (0w-40): 4.35ppm per 1K miles
2nd UOA (5w-30): 6.55ppm per 1K miles
3rd UOA (0w-40): 5.00ppm per 1K miles
Al:
1st UOA (0w-40): 1.09ppm per 1K miles
2nd UOA (5w-30): 2.49ppm per 1K miles
3rd UOA (0w-40): 1.33ppm per 1K miles
They both got the job done, but one is half the price
The new BMW oil is Shell, this is all the old Castrol supplied stuff.
Euro oils get the job done.
Subaru coolant conditioner is a good porosity/small leak sealer.
Even with the new filter housing gaskets, I'd consider it.
I'll look into that. Thanks for the tip.
