This is a very common problem apparently with no solution. I have searched all over the Acura forums. Earlier models had the infamous HFL parasitic draw which actually killed the battery in a couple days but this problem was solved by 2008. In my case, I keep getting a Replace Battery message even though my battery and alternator are good. Just to rule it out, I disconnected the HFL module and checked for parasitic draw. Everything ok. Pretty sure that if a solution existed it would be available on an Acura forum, but I thought I would ask here just in case. Acura says it is a software glitch. Thx for your help.
