- Joined
- Sep 26, 2010
- Messages
- 9,807
Gang,
Here is the 3rd UOA (and may be the last) for my Brute Force 750 ATV. These engines are oil shredders, but the Rotella T-6 held up VERY nicely. I refilled with QS Defy 10W-40, but I will return to T-6 after I have used all of the Defy from the Amazon deal and will double the OCI (depending on riding conditions and heat as these engines run excessively hot--but I have a Derale oil cooler to install soon).
Blackstone comments below and thoughts are always welcome:
Most of the wear metals improved again in this sample from your Kawasaki. The engine has made it through the wear-in process with flying colors and should start developing some nice wear patterns from here. Low insolubles and silicon show good oil and air filtration. You're concerned about fuel dilution and shearing, but the flashpoint was high enough to show no measurable fuel and the viscosity right on the mark for 5W/40. The TBN was strong at 8.8 so there's still a lot of active additive left. All is well at 27 total hours.
Code:
Year: 2010 Make: Kawasaki Model: KVF-750 Brute Force Engine: 750cc V-Twin
Date: 08/03/12 11/22/11 05/01/11
Oil Brand/Type: Rotella T6 KAWA KAWA
Oil Viscosity: 5W-40 10W-40 10W-40
API Service: SM SM SM
Oil Filter: KAWA OEM KAWA OEM KAWA OEM
Air Filter: PureOne PureOne KAWA OEM
Lab: BLKST BLKST BLKST
ATV Hours: 27 17 10
Oil Hours: 10 7 10
Aluminum: 2 2 9
Chromium 0 0 1
Iron: 6 8 46
Copper: 8 21 150
Lead: 3 10 26
Tin: 0 0 0
Molybdenum: 63 44 40
Nickel: 0 0 1
Manganese: 0 1 4
Silver: 1 0 0
Titanium: 0 0 0
Potassium: 3 3 3
Boron: 67 78 3
Silicon: 21 15 57
Sodium: 6 2 10
Calcium: 996 1712 1510
Magnesium: 1071 10 35
Phosphorus: 1051 827 853
Zinc: 1248 916 941
Barium: 0 2 14
SUS Viscosity @ 210°F 68.8 68.0 55.5
cSt Visc. @ 100°C 12.63 12.42 8.93
Flashpoint in °F 400 400 380
Fuel %
Antifreeze % 0.0 0.0 0.0
Water % 0.0 0.0 0.0
Insolubles % 0.0 0.0 0.4
TBN 8.8 -- 3.1
Code:
ATV Hours: 27 17 10
Oil Hours: 10 7 10
Aluminum: 2 2 9
Chromium 0 0 1
Iron: 6 8 46
Copper: 8 21 150
Lead: 3 10 26
Tin: 0 0 0
Nickel: 0 0 1
Manganese: 0 1 4
Silver: 1 0 0
Titanium: 0 0 0
Potassium: 3 3 3
Boron: 67 78 3
Silicon: 21 15 57
Sodium: 6 2 10
Zinc: 1248 916 941
Barium: 0 2 14
Fuel %
Water % 0.0 0.0 0.0
TBN 8.8 -- 3.1
