60% highway. Due to the problems with the 3.5, I think I'll stick with 5-6k oil changes. This was QSUD 5W20 w/ Bosch filter. Refilled with PU and a Bosch D+.
From Blackstone:
Your Honda engine is slowly dropping the highlights and with any luck the next sample will be perfect. As it stands, the engine is wearing a little more at steel parts than we'd like, but we doubt that's from a serious problem. If this
engine sees a lot of idling, then iron at this level may very well turn out to be normal. The oil seems to be holding up just fine, based on the normal viscosity, low insolubles and strong TBN of 3.5. Try going up to 7,000 miles for your next oil run. We'll keep an eye on iron.
Alum: 6
Chrom: 1
Iron: 32
Copper: 18
Lead: 1
Tin: 1
Moly: 36
Nickel: 0
Mangan: 1
Silver: 0
Titanium: 0
Potassium: 2
Boron: 3
Sodium: 105
Calcium: 2035
Magnesium: 58
Phosphorus: 602
Zinc: 714
Baruim: 0
SUS Vis: 513
cSt Visc: 7.67
Flashpoint: 370
Fuel %: 0.5
Antifrz, Water, Insol: 0
TBN: 3.5
