- Joined
- Sep 26, 2010
- Messages
- 9,467
Gang,
Below is UOA #19 for my FX4 and is another good showing for M1 AFE 0W-20. I should have kept it in longer, but I thought the TBN was going to be lower (live and learn). I will definitely run this fresh load out to 20K and see how it is doing. Of the three oils used in this truck, the M1 is the smoothest and performed the best--compare to the lower mileage MS5K runs. I also really like the low insolubles despite the longest run to date. The air filter was changed right after the 10K UOA (the 10K UOA and this one is the same load). Blackstone comments are below and your thoughts and comments always welcome.
PS...Tig--I am pretty sure that you can extend past 10K
2010_FX4: You said you were interested in the TBN, and it looks perfectly fine here at 2.9. There's still plenty of active additive left for a longer oil run, even after more than 15,000 miles on the oil. Wear hasn't changed much at all since the last sample, and this oil has about 5,000 more miles on it. You've got one nice engine on your hands, that's for sure. No harmful contaminants were found, and the TAN was 5.0 (a little more acidic than last time). Shoot for 17,500 miles next time. We think this engine will be able to handle that just fine.
Code:
Year: 2010 Make: Ford Model: F-150 FX4 Engine: 5.4L FFV Transmission: 6R80 Axle: 9.75 Ford ELD (3.73) - - SYNTHETIC <<--]|[-->> CONVENTIONAL CONVENTIONAL <<--]|[-->> SYNTHETIC | | | | Date: 11/13 10/13 | 07/13 04/13 11/12 08/12 06/12 | 05/12 02/12 11/11 09/11 07/11 06/11 05/11 03/11 02/11 01/11 10/10 9/10 Oil Brand/Type: M1 M1 | MS5K MS5K MS5K MS5K MS5K | PU PU PU PU PU PU PU PU PU PU PU MC Oil Viscosity: 0W-20 0W-20 | 5W-20 5W-20 5W-20 5W-20 5W-20 | 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 API Service: SN SN | SN SN SN SN SN | SM{A} SM SM SM SM SM SM SM SM SM SM SM Oil Filter: MC MC | MC MC MC MC MC | MC MC MC MC MC MC MC MC MC MC MC MC Air Filter: NG NG{B} | NG NG NG NG NG | NG NG{B} MC MC MC MC{B} MC MC MC MC MC MC Lab: BLKST BLKST | BLKST BLKST BLKST BLKST BLKST | BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST | | Truck Mileage: 121,637 116,433 | 106,265 99,231 89,211 80,927 74,447 | 69,305 62,055 54,575 47,075 39,770 32,280 27,100 21,600 16,600 10,600 4,500 991 Oil Mileage: 15,372 10,168 | 7,394 10,020 8,285 6,480 5,142 | 7,250 7,480 7,500 7,305 7,490 5,180 5,500 5,000 6,000 6,100 3,509 991 | | Make-Up Oil: 0.75 0.0 | 0.0 0.5 0.5 0.0 0.0 | 0.0 0.25 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 | | Aluminum: 4 2 | 2 3 3 2 2 | 3 3 5 3 2 2 3 3 6 3 3 3 Chromium 1 1 | 1 1 1 1 1 | 1 1 1 1 1 1 1 1 1 1 1 0 Iron: 14 10 | 10 16 12 10 10 | 11 8 13 8 9 7 9 10 18 13 10 18 Copper: 2 1 | 2 2 2 2 1 | 2 1 2 2 2 2 3 4 4 5 9 41 Lead: 0 0 | 1 0 0 0 1 | 0 0 0 0 0 0 0 0 0 0 0 2 Tin: 2 1 | 0 2 1 4 0 | 0 0 1 0 0 0 0 0 0 0 0 0 Molybdenum: 83 75 | 6 3 6 3 11 | 48 56 46 47 58 55 54 45 47 52 48 42 Nickel: 0 0 | 1 1 1 1 0 | 0 1 0 0 0 0 1 0 0 0 0 0 Manganese: 1 1 | 1 1 1 1 0 | 0 0 1 0 0 0 0 1 1 1 2 10 Silver: 0 0 | 0 0 0 0 0 | 0 0 0 0 0 0 0 0 0 0 0 0 Titanium: 2 2 | 27 34 32 30 24 | 2 0 0 0 0 0 0 1 0 0 0 0 Potassium: 3 0 | 2 0 4 4 2 | 6 0 6 5 1 0 2 3 4 2 3 14 Boron: 34 35 | 9 3 4 7 9 | 91 249 156 144 156 233 244 230 249 278 258 272 Silicon: 15 14 | 11 12 12 11 12 | 13 11 16 19 21 19 19 17 16 29 45 111 Sodium: 108 99 | 323 369 362 374 284 | 4 4 7 5 3 3 3 4 4 4 4 9 Calcium: 1264 1236 | 2179 2200 2276 1954 2195 | 2647 3168 3003 3053 2941 2900 2814 2613 2740 2911 2706 2203 Magnesium: 792 768 | 15 19 19 12 15 | 17 15 17 17 16 12 12 11 12 12 12 14 Phosphorus: 686 668 | 697 706 735 624 655 | 688 728 671 668 710 713 676 608 629 691 643 773 Zinc: 752 784 | 822 832 797 738 765 | 762 820 724 743 861 834 813 675 718 774 752 835 Barium: 0 0 | 0 0 0 0 0 | 0 0 0 0 0 0 0 0 0 0 1 16 | | SUS Viscosity @ 210°F 52.0 51.2 | 50.7 51.4 52.3 52.6 51.5 | 53.5 53.2 52.2 51.7 53.9 52.5 52.9 53.1 52.8 51.5 52.2 49.4 cSt Visc. @ 100°C (UOA) 7.89 7.63 | 7.49 7.69 7.96 8.05 7.73 | 8.34 8.25 7.93 7.80 8.45 8.04 8.14 8.21 8.12 7.72 7.94 7.09 | | VOA Mobil cSt Visc. @ 100°C 8.6 8.6 | 7.48 7.48 7.48 7.48 7.48 | --- --- --- --- --- --- --- --- --- --- --- --- MOBIL cSt Visc. @ 100°C 8.7 8.7 | 8.4 8.4 8.4 8.4 8.4 | --- --- --- --- --- --- --- --- --- --- --- --- | | VOA PU cSt Visc. @ 100°C --- --- | --- --- --- --- --- | 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 --- SOPUS cSt Visc. @ 100°C --- --- | --- --- --- --- --- | 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 --- | | Flashpoint in °F (UOA) 405 400 | 400 3 95 510 390 {C} | 415 405 420 415 410 425 405 390 410 390 400 390 MOBIL Flashpoint in °F 435 435 | 446 446 446 446 446 | --- --- --- --- --- --- --- --- --- --- --- --- SOPUS Flashpoint in °F --- --- | --- --- --- --- --- | 435 435 435 435 435 435 435 435 435 435 435 --- | | Fuel % <0.5 <0.5 | <0.5 <0.5 <0.5 <0.5 {C} |<0.5 <0.5 <0.5 <0.5 <0.5 <0.5 <0.5 <0.5 <0.5 <0.5 <0.5 <0.5 Antifreeze % 0.0 0.0 | 0.0 0.0 0.0 0.0 0.0 | 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 Water % 0.0 0.0 | 0.0 0.0 0.2 0.0 0.0 | 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 Insolubles % 0.1 0.1 | 0.3 0.4 0.4 0.2 0.1 | 0.3 0.3 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.1 TBN 2.9 2.2 | 2.5 1.4 2.7 2.6 3.7 | --- --- --- 5.4 --- --- 5.6 4.8 5.3 9.4 7.5 --- TAN 5.0 4.3 | 2.3 3.0 2.6 4.3 --- | --- --- --- --- --- --- --- --- --- --- --- --- | | | | SYNTHETIC <<--]|[-->> CONVENTIONAL CONVENTIONAL <<--]|[-->> SYNTHETIC - - NOTES: Acronyms: BLKST=Blackstone M1=Mobil 1 | MS5K=Mobil Super 5000 | PU=Pennzoil Ultra {A} Possibly SN in SM bottle; note drop in Calcium {B} Air filter change; MC=Motorcraft, NG=Napa Gold {C} Blackstone spilled sample; not enough to test FP and Fuel%
