I have a 2010 Fusion with the 2.5L I-4 with 91k miles. The engine notoriously has a noisy valvetrain, and that is not what I am concerned about. I drove the car only twice in the last two weeks, both times startup was after a week of not running and temps were about 25F. Upon startup, I had a noticeable rod knock until the oil warmed up and circulated a bit. I know what a rod knock sounds like, I replaced rod bearings in my previous car (Dodge Intrepid) because it developed a knock at 150k miles.
I'm running Amsoil XL 5w-20, same for about 4 oil changes now. Previous oil changes I was adding one bottle of ZDDP Maxx which quieted down the valve train and I never heard the rod knock on startup (granted it never sat a week before). From UOAs, the ZDDP greatly reduced my wear metal numbers from the previous changes without it. Could this additive have been masking the rod knock, or is it just because it sat a week and all the oil drained out?
Should I go back to using the additive? Any other additives recommended? I've been thinking of trying Archoil.
Also, with 91k, would it be advisable to switch to a 5w-30 instead of the specified 5w-20? The car was previously a lease and fleet maintained, so I'm wondering if they had run 5-30 a lot and did some bearing damage. The engine was quieter (less valvetrain noise) before I did the first oil change to 5w-20, which is why I'm wondering if they ran something heavier.
Thanks for any input!
