2010 Ford F-150 4.6L w/ 4 sp auto, transfer case linkage replacement
Kentucky
Helping a friend out-- Truck in question is a fairly base model 2010 Ford F-150 w/ the 4.6L 2-valve, 4 speed auto, and one of the old school transfer cases w/ mechanical linkage.
In this nasty weather, his attempt to get into 4WD resulted in a clunk and he wasn't able to get the shifter to engage 2WD or 4WD, it seemed stuck in between positions or perhaps neutral. He had it towed to Big-O, they diagnosed it as a failed shifter linkage, with the part only available through Ford. Total quote was just north of $800 for parts and labor.
Has anyone ever seen or experienced this issue? He asked me to help and I'd like to save the guy money with the repair if the part is readily available and it's not a clusterf** of a job, which I can't imagine it would be. Some rudimentary parts searching shows it comes as a complete assembly w/ cable and shifter together as a unit. Any input/help would be appreciated!
No experience here but, the linkage may not be the only issue here. If the linkage is not exercised on a regular basis there may be more than meets the eye here; just my 2 cents. I have seen this with other models.
I'll probably have him bring it over and leave it here so I can look at it before ordering any parts.
The transfer case itself is fine, Big-O was able to operate the transfer case manually, ultimately putting in back in 2WD to get him back on the road.
