Originally Posted by Whimsey
Originally Posted by dogememe
[q
The ONLY thing I'm worried about in terms of making it over 200K miles is the 6F35 transmission. Then again I had an 08 Escape with the "unreliable junk" CD4E and it still is fine on the original engine and trans at 220K miles and counting...
SirTanon has a Fusion with ~260,000 miles with the original 6F35 transmission. The secret is doing reasonable ATF drain and fills, say every ~20-30,000 miles. Ford says the factory fill is good to 150,000 miles, 90,000 miles AFTER your power train warranty expired
. With our new 2017 Explorer that has the same transmission I'm doing 3 ~11-12,000 mi d&f then I'll go to ~25,000mi d&f. It's easier to do the d&f than change the oil & filter.
Yup I'm doing double-drain-and-fills with Maxlife ATF every approx. 15-20k miles
when it starts to come out clean and not get black right away I'm going to settle on a single drain and fill every 30K.
