Howdy BITOG,
My daughter's car is a 2009 Focus (great car). One thing with this car however confuses me. If you let the car sit overnight, and then walk up and pull the stick it will generally read below the "safe" zone, over a quart low. Wipe it and put the stick right back in, and it will show correctly topped off on the next pull.
If I let it sit for a few minutes after running hot and check it then, it will also show correct levels.
I have always preferred to let check cars stone cold for what I considered the most accurate reading. I can't understand why it would show low when sitting especially when it doesn't show low if you put the stick right back in and check again without having started it.
Anybody seen this before? I have been going with the wipe and recheck reading but I don't want to be running it low if I am somehow missing something.
