M meep Joined Feb 20, 2007 Messages 7,773 Location Southeast May 15, 2022 #21 Agree. Change it, don’t flush it. Time for the filter too. In a few months, do a drain/fill again, without the pan drop. If it runs and shifts well, no harm in using a higher tier fluid.
Egg_Head Joined Oct 7, 2012 Messages 1,311 Location North Carolina May 16, 2022 #22 You can extract about 4-5 quarts of ATF topside with a Mityvac or similar device.
L Lubener Joined Jan 22, 2011 Messages 9,557 May 17, 2022 #23 Egg_Head said: You can extract about 4-5 quarts of ATF topside with a Mityvac or similar device. Click to expand... Better off dropping pan to access the filter.
Egg_Head Joined Oct 7, 2012 Messages 1,311 Location North Carolina May 17, 2022 #24 Lubener said: Better off dropping pan to access the filter. Click to expand... I agree. This method for subsequent D&F. On 4WD models, that filter and pan are a major PITA to remove unless you buy a new pan with plug.
