2008 Nissan Titan Shell Rotella T6 5w40 UOA Result
Florida
2008 Nissan Titan Crew Cab 2wd. VK56DE V8, No additives, and using Wix filter
141910 Miles
Oil Test mileage 3800
Sample Date 02/4/2016
Blackstone UOA Results.
Code:
CORY: We don't have much of anything bad to say about these results. The only mark on the page is for the flashpoint. That does show a small amount of fuel dilution, but 1.0% isn't enough to show or cause any problems with the engine. What's really good to see are the low wear levels. Universal averages show typical wear for this type of Nissan with oil run about 5,700 miles. This fill wasn't in service for quite that long, so wear should be below average, and it is.
The TBN was good and strong at 7.2 -- 1.0 or less is toolow. No coolant or dirt (high silicon) found.
ALUMINUM 2
CHROMIUM 0
IRON 8
COPPER 0
LEAD 1
TIN 1
MOLYBDENUM 65
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 67
SILICON 7
SODIUM 6
CALCIUM 1043
MAGNESIUM 917
PHOSPHORUS 940
ZINC 1126
BARIUM 0
cSt Viscosity @ 100°C 67.8
SUS Viscosity @ 210°F 12.38
Flashpoint in °F 355
Fuel % 1.0
Antifreeze % 0
Water % 0
Insolubles % TR
TBN 7.2
TAN
ISO Code
I just did an oil change with same Rotella T6 5w40 and going to go for 5500 miles this time.
My Titan isn't stock either, has bolt ons and other components.
Heck with the TBN left you can go well beyond 5000 miles!
Stout oil for sure! Nothing better than SOPUS products, heck I don't think M1 oils have that much TBN when new!
