2008 Nissan Frontier TPMS question
Champlain/Hudson Valley
My friend has a 2008 Nissan Frontier and the TPMS light is on.
There are no low tires and he's heard that the TPMS sending units in each wheel last longer than the 8-9 years of age his vehicle is.
He also heard some "advice" that there is a white wire (accessible in the center stack) which needs to be cut and rigged to be shorted to ground occasionally.
This was said to reset the TPMS warning light.
Does anybody have any experience or facts on this?
Going by what he's heard: I'd cut into the "white wire" and connect it to one side of a switch and route the other side of the switch to a ground.
ERGO: When the switch was closed it would go to ground and when the switch was open the circuit would be normal.
Any poop on TPMS circuitry out there? Kira
If you know that all the sensors are working the paper clip trick works. Have used twice now on my 06 Xterra. Visit a local Walmart or some tire shops will test each sender for free. I had one go bad and got a used sender off ebay for $13 with a install pack(new oring, valve core and cap)I installed myself. No need to dismount tire, just unseat tire from the valve side and remove the old unit and fish in the new sender.
