My mom has a 2008 Malibu with around 85k on it and I don't believe the trans fluid has ever been changed, it's one of those annoying ones without a dipstick, I was wondering how important is it that the whole vehicle is level when you crack the level bolt, to those with knowledge of the transmission is the bolt centered in the case to where if you crack it open with the car up on ramps it doesn't make much difference compared to if the car was on flat level ground or does it really have to be completely flat where a better way to do it yourself would be similar to how FordTechMakuloco showed on the 6F35 on the 2013+ Escape and Fusion where you jack the car up at the pinch weld and take the tire off and lower the jack to where the car is level then crack the bolt that you can now reach with the tire removed, because I think the level bolt is sort of similarly on the drivers side of the transmission on the Malibu.
