This is weird.... Driving home the other day and noticed I was deeper into the throttle than usual. I thought I was losing power to my engine and pulled over into a parking lot, placed it park and began to smell that acrid smell of burning brakes.
Got out of the vehicle and noticed my front-left disc brake was giving-off heat and smell. In fact, when I tried to pull ahead to a safer spot, I could barely get the car to move. **** front brake seemed to be clamped-down all by itself.
Anyhow.... had it towed home thinking a caliper froze-up and decided I'd repair it myself. (Still plenty of pad material intact and never had an issue. Also, I have completed brake jobs before.)
So... Replaced the caliper, pads, resurfaced the rotor, flushed, and bled the system. Nope! Locked again just as I was driving out of the neighborhood.
Went back in... purchased a new master cylinder and brake line. Replaced those and flushed the entire brake system (all 4-wheels).
Nope! That front caliper is clenched so hard it won't let go. Crazy huh? Now... I'm thinking some funky ABS issue is kicking-in and sending pressure to that front caliper for some weird reason.
Anyone have any ideas or have dealt with this before? I'm lost at where to start again... ABS? Can the module or pump be at fault?
Thank you ahead of time. I'm hoping someone might have a clue.
Thank you!
Thank you!
