Problem all summer... hit a bump and car swerves... front control arm replaced... new right tie rod thing replaced... aligned... still doing it... thinkin rear shock bad... any input?? Just put 450$ into it... thanks
Along with the above, recheck the tie rod end to be certain it was torqued properly and the alignment is still set as it should be. Also check for worn out sway bar end links. Those can cause "stealth" problems and are fairly inexpensive to replace.
Originally Posted By: Jimzz
Dumb question, has the tires been rotated and the air pressure checked? many skip this basic step and go to more costly parts to quick.
+1 are your tires directional? Could it be tramlining badly?
Who are you paying to trouble-shoot this? My recommendation is to poll those in the know and take this thing to someone who knows what they're doing. $450 is a lot of money to pay for NOT fixing a cheap, throwaway car like that.
Thanks for the info... been sitting here drinking coffee this morning... my problems with the car started end of June... I want to throw this at you guys... end of June car was flat bedded almost 100 miles with electrical issue... after that the handling problems developed...
Gonna get tires rotated and balanced... start looking for shocks... thanks again...
While it may be just a coincidence that the issue came up after a tow - I would be looking for bent parts.
With a wheel or dolly tow, only the wheels are secured (not counting the safety chain) and the car moves and rocks on it's own suspension.
A typical flatbed tow is a bit different. The car is chained down at the back of the bed and then pulled tight with the winch then secured with load binder chains at the winch end. This leaves the car in traction (as in funny hospital scene with a person's leg in a cast hung and stretched by a hideous medical contraption) and somewhat compressed on it's suspension. Every bumps sends a shock to the chain points but worse are the dips that cause the car to compress further and relax the chains. As the car springs back against the chains some pretty harsh forces are generated.
Back when cars had frames there were chain slots all over and tying down a car was easy. Now what few slot there are in frameless cars are covered by trim and drag reducers and tow drivers either can't find them or are too tired/lazy to look and will wrap chains around any convenient thing at hand like sway bars, control arms. and even FWD axles.
That 100 mile tow could have put your car through more punishment than a weekend Baja rally with Rosie O'Donnell as co-pilot.
back in my late college days, I had a Mazda B2 block (Ford Festiva equiv) which was tow-damaged. 1 of the 2 rear shocks leaked after the tow. Tow company obviously won't pay, so I bought some monroe (re-labeled Austrian made with V-W stamped on it) replacements and swapped them out in pairs.
bet yours (1 or both of them) may have been damaged that way also (that's why I said change the struts/shocks on the rears).
