Pitbull
Originally Posted By: SpitfireS
The Aston Martin may be art.. on the outside.
The mechanics of the internal combustion engine are no different from the Hyundai parked next to it.
When the "Euro-spec" 10W-60 oils shear down to a 40 weight... why not use a stay-in-grade 40 weight to begin with?
The only reason may be: warranty.
The redline of an engine has little to do with the need for thick "racing" oils.
My S2000 / F20C2 redlines at 9000 rpm and the factory recommended oil is dino 10W-30.
In high revving engines I think its better to have thinner oils to increase oil flow at high revs, thick oil will not make it past the pump bypass valve at higher revs (= higher pressure).
Street engines requiring "racing oils" is just a load of blah blah blah
in my book.
It is a hand built V8 with a 7500 rpm redline and has dry sump with 2 oil pumps. Figure the guys that built it should know the best oil for the engine. Who knows but since I am not an expert I wanted to make sure I was running the correct oil, I understand the 5w30 Castrol Syntec did not hurt it for the 400 miles it was in the engine but why take a chance with a $140,000 car?
