2007 Mitsubishi rear brakes
conneaut ohio
I can't get the rotor off due to the ebrake Does anyone know where the adjustment is off hand or any tricks to removing the rotors? Thanks
I got it. There is a rubber plug on drum part of rotor pop that out and put on bottom , look for the adjuster (star) adjust to loosen (bottom to top) then thread 2 bolts in threaded holes and tighten evenly till it's off. Need about 2 in. bolts I don't know thread size I just pulled 2 out of bolt box and they fit.
Originally Posted By: duaneb9729
Thank you for sharing your experience's!!
I like to finish a thread with the answer or outcome so someone searching for answers and finds a thread finds a answer not a deadend
Which Mitsu is this for, sorry?
Also found that so much rust built up under stainless slides that brakes were locked tight. Needed to use hammer to get pads out of slides (anti rattle clips) so I removed clips and filed rust away then applied neversieze shouldn't happen again
