G glenncof Joined May 31, 2006 Messages 1,051 Location Northern California Aug 1, 2007 #1 For those of you that study ACEA spec. www.acea.be/files/070308%20ACEA%20sequences%202007%20LD%20and%20HD.pdf
E Eddie Joined Dec 7, 2003 Messages 12,360 Location Florida, Cape Coral Aug 1, 2007 #2 Interesting read. Am I correct in assuming that an oil rated as A5B5 is a step up on A1B1?
T TallPaul Joined Oct 22, 2003 Messages 13,131 Location By Detroit Aug 1, 2007 #3 Looks like the main difference between A1/A5 and A3 is the higher HTHS of A3.
H HondaMan Joined Apr 6, 2005 Messages 671 Location Texas Aug 1, 2007 #4 I like the depiction of the older CCMC Gx migration path. Many older BMWs etc that called for the older CCMC specs. I think if I remember correctly, my 96 BMW would call for an A5 based on the current path.
G glenncof Thread starter Joined May 31, 2006 Messages 1,051 Location Northern California Aug 1, 2007 #5 A5 a step up? Compare carefully to A1. At this point in my understanding it is a minor step up. Seems differences are more diesel oriented. HondaMan, as you probably know BMW has there own LL-98, LL-01, LL-04 spec's (long life). This is another story. Last edited: Aug 1, 2007
G gtx510 Joined Apr 26, 2004 Messages 1,463 Location CA Aug 2, 2007 #6 BMW's LL oils are all A3/B3 or A3/B3/B4. They're kinda like a low-SAPS HDEO. A1/A5 oils are like our GF-4, "Energy Conserving", starburst oils. http://www.infineum.com/information/consumer.html same ACEA info http://www.infineum.com/information/tables.html more API and ACEA info
G-MAN Joined Nov 15, 2002 Messages 8,937 Location SC Aug 2, 2007 #7 Quote: A5 a step up? Compare carefully to A1. At this point in my understanding it is a minor step up. Seems differences are more diesel oriented. Click to expand... The primary difference between A1 and A5 is that A5 is an extended drain spec.
G glenncof Thread starter Joined May 31, 2006 Messages 1,051 Location Northern California Aug 2, 2007 #8 What makes it "extended" drain ? A1 vs A5 looks useful for evaluating 0W20 and 5W20 oils.
