2006 LBZ Duramax, 5,300mi, Delvac1 CK-4
Richmond, VA
Previous UOA for reference: HERE I left the truck tuned as it was before and cleaned the air filter. Started off with a NAPA Platinum Filter then, after receiving the previous UOA, I installed a Fram HM9100 ($1.50 @ WM) at 981mi into this oil change. I did not top it off when I changed the filter. At 5314mi I sampled the oil via the oil filter housing; I removed the filter and let the oil from the center of the housing drip in the sample bottle. Now the truck has a Fram Ultra installed and I added 1/2 quart to get back to full.
Code:
MI/HR on Oil			5,314			15,592			10,746			21,466			13,893
MI/HR on Unit			148,361			143,047			127,455			106,671			85,205
Sample Date			08/05/17		05/03/17		08/10/14		01/13/14		03/05/12
Oil				Delvac1 ESP CK-4	M1 TDT			Rotella T5 		Rotella T6 5w-40	Rotella T6 5w-40
				5W-40			5W-40			10w-30
Make Up Oil Added		0 qts			0 qts			0 qts			.5 qts (Filter)		0 qts
ALUMINUM			3			4			4			6			6
CHROMIUM			<1			2			<1			<1			1
IRON				23			47			49			24			34
COPPER				1			4			3			4			14
LEAD				<1			4			2			1			0
TIN				3			3			2			2			3
MOLYBDENUM			36			2			3			67			62
NICKEL				<1			4			<1			<1			0
MANGANESE			Not Tested		Not Tested		Not Tested		Not Tested		1
SILVER				<1			<1			<1			<1			0
TITANIUM			<1			<1			<1			<1			0
POTASSIUM			2			<1			<1			<5			7
BORON				76			43			15			23			38
SILICON				7			13			11			6			8
SODIUM				1			8			5			10			4
CALCIUM				1212			1354			2517			860			970
MAGNESIUM			828			990			50			1171			1258
PHOSPHORUS			981			1185			1091			1070			1098
ZINC				1207			1385			1254			1312			1309
BARIUM							<1			<1			<1			0
SUS Viscosity @ 210°F		Not Tested		Not Tested		Not Tested		Not Tested		77.3
cSt Viscosity @ 100°C		13.3			17.0			12.7			15.0			14.84
Flashpoint in °F		Not Tested		Not Tested		Not Tested		Not Tested		420
Fuel %				<1			<1			<1			<1			<0.5
Antifreeze %			No			No			No			No			0.0
Water %				<0.05			<0.05			<0.05			0.07			0.0
Insolubles %			0.6			1.6			0.5			0.3			0.1
TBN				8.8			7.0			6.1			7.2			8.3
Originally Posted By: stockrex
"Cleaned the air filter" K&N ?
I would guess so too. Silicon value is pretty good in this sample .... so whatever the airfilter is its not doing a bad job. But if I calculate the numbers of this sample to the milage of Mobil 1 TDT, TDT has done a better job ... and still had a 17 cSt after 15000 miles?
It's a 10 year old AFE ProGuard 7-Layer. The TDT from the previous fill was CJ-4
Delvac 1 ESP 5W-40 has moly in it now? This is new for the CK-4 formula? On the older UOAs of Delvac 1, there wasn't any moly to speak of, right?
