Originally Posted By: Best F100
I am curious about what you think of the CVT transmission? I have heard of some Freestyle owners who had their CVT fail in as early as 50,000 miles.
Of course Ford only offered this transmission for a couple of years, for this model. Replacement cost for them is over $2 Grand if memory serves me. What kind of maintenance intervals on it?
Well, I'll though my answer out there since I own one. I absolutely love the transmission. I generally dislike automatics, but there are very few cars in this category with manual transmissions. After owning this car I would never buy an automatic that wasn't a CVT (MT is still my first choice). It's always in the right gear, the driveability is really perfect for what this car is, a giant wagon. It feels slightly sluggish off the line, but it's actually quicker than it feels--it's mostly a sensations thing. And if launching from a start is your priority, then you shouldn't be buying a Freestyle anyway... When it matters, say 30-60mph, merging onto the highway or passing, the torque converter locks up immediately and it behaves like a normal car. The the revs drop. Mostly, I love the fact that it has low revs on the highway, is seamless when going over mountain passes and I get ridiculous gas mileage for an AWD car of this size (22-23 mixed, 26-29 hwy).
All transmissions will have some early failures, but the actual numbers are quite small. If you look at all of the independent sources of data, the failure rates are quite low. The most common failure mode is failure of the input shaft. The one issue with the transmission is that parts are hard to find, and techs familiar with the transmission are even harder to find! And a replacement is going to run more than 2K. If mine ever goes and I'm not able to fix it, I'll probably swap in the Aisin 6 speed from the Ford Fivehundred. This also means I'll be converting the car to FWD, which isn't the end of the world. But honestly, I'm not too worried about it. I have 110K on mine right now and it acts like new.
The factory-recommended service intervals are 60K for the full-flow filter, along with a recommended drain and fill. A drain and fill gets out about 6.5 qts out of 10qt total capacity. I'm doing a drain and fill every 25-30K and the filter every 50-60K. It also has a second, conventional 'rock catcher' filter in the pan, but I'm not touching that until the pan starts weeping or 200K, whichever comes first. The car has a drain plug and a fill plug for the transmission, which is awfully nice to have these day.
