- Joined
- Sep 28, 2002
- Messages
- 39,799
Take pictures
Quote:
Got the mount base for the B50 in today. Intersesting. It is no wider than necessary to fit the filter in it's diameter, and just enough back bracket to mount it. I like the small and compact designe of this filter mount. No extra overhangs.
Images can be kind of a bugger if you are not used to UBB code. You have to have an image loaded onto some other website that hosts your image and them refer to in in a link from here. Also....make sure the image is within reason for size. Anything in hundreds of pixels, ie 700K size will load a lot slower than somehting in the 88k size. and if it's it's megapixel ie 2.2M it would be prohibitively large file to load on every time you visited this page. Every picture every ikon takes a bit of time to load, even the smilely take more time to load on a page, overall.
The Darth Sidious image is only 2.86k and takes practically no time at all to load up. The FAQ should steer you onto some info as far as images and how to manipulate or load them.
Quote:
How in the world do you up load pic Here ?
Col.
Quote:
You'll probably be looking mainly for soot level. If you can keep that under control ..or so it seems with the oil burners ..you can really extend your drains. When you post it in the Diesel UOA section, there will be loads of pals to tell you what's great and lousy with your oil.
