I would like to change the differential fluid in my wife's 2005 Yukon XL. It looks like the crossmember and sway bar are in the way of taking the cover off. It looks like it might clear if the rear of vehicle is raised. Does anybody know if the cover can be removed and replaced without unbolting, moving or removing the crossmember/sway bar ???
My old '88 GMC Suburban is a lot easier to work on than this new Yukon.
Also what is a good mileage for the first differential fluid change ? I have heard that an early change to get out any metal debris etc will extend the life of the differential considerably.
Also what is a good fluid to use ?
