Vehicle is our 2005 Mercury Mariner with 187K miles on the factory 3.0L V6. Bought new right off the car hauler still with plastic covers on the seats. Oil was D1G2 labeled Valvoline Synthetic High Mileage 5W-30, and Fram XG2 oil filter.
During this OCI, it overheated once due to a stuck thermostat and had one or more fuel injectors leaking gas during shutdowns at operating temp. Thus the reason for the lab analysis, checking for coolant in oil (head gasket damaged) and/or the expected fuel in oil. Any observations are appreciated.
Sodium: Existing UOA posts with Valvoline synthetics show significant sodium, so I presume the 252ppm reading is not abnormal. Potassium is within spec limits it seems. No coolant loss observed since the new water pump and thermostat went in nearly 900 miles ago.
Fuel: The lack of fuel detected is surprising. The vehicle was having hot start problems consistent with injector leakage: restart within a few seconds of hot shutoff was abnormally immediate upon cranking and accompanied by spark knock, restart after 30-60 minutes of hot shutoff took ~5 sec of cranking followed by a rough startup and puff of black smoke out the exhaust. Factory injectors (Deka 4L8E-A4A) were pulled and sent to a reputable shop for testing, cleaning, and re-testing...they passed all tests both before and after cleaning, including 100psi static leakdown test. Operating pressure is 40psi. I replaced them with the superseding Ford injectors (purple band at base of injector housing, 4B4 part # suffix etched)...and no further hot restart problems. I expected to see fuel in this oil.
