Car: 2005 Cadillac CTS
Engine: 3.6L V6 VVT
quantity oil in engine: 5.7L
miles on unit: 111 459 miles
mles on oil: 7747 miles (3 months)
80%highway 10%city 10%idle
type of oil: PP 5w30
oil life monitor: 23% oil life left (changed the oil when it was at 88%)
make-up oil: 2 qts.
The first column is from Mobil 1 5w30 supersyn with 10k miles on the OCI with 92,5k miles on the odometer.
Al- 4 - 2
Pb- 9 - 3
Cu- 3 - 1
Fe- 40 - 16
cr- 1 - none
ni- 1 - ?
Mo- 91 - 60
mg- 15 - 12
B- 62 - 37
Na- 8 - none
Ca- 2410 - 3094
P- 712 - 757
Mn- 2 - 1
Zn- 820 - 868
K- 5 - none
Soot: 0% - 0
Water: cSt at 40 deg C: 52.81 - 57.70
cSt at 100 deg C: 9.41 - 10.10
TBN: 5.18 - 6.31
dilution (volatile): 0% - 0.50%
Viscosity Index: 158.00 - 164.00
When I first did my oil change, I put M1 10w30 because I couldn't find anywhere M1 5w30. Since the 10w30 is 4718m spec, I said it was the same thing but my car didn't like it. It drank 1 qt per 800 miles or so. So after 2k miles, I switched to PP 5w30. The oil consumption reduced a lot. I didn't run the oil life monitor to 0% because I'm going for a business trip any day soon and I couldn't wait to see the results. Now, the M1 5w30 is back in the crankcase.
Feel free for comments.
btw, the oil filter is the OEM cartridge from the dealer.
I put 10% of idling but it can be a lot more since I can't tell hw many times a day does the car idle. Approx 45-60 minutes/5 days a week a day since I do all the paperwork in my car with the air conditionning working.
Engine: 3.6L V6 VVT
make-up oil: 2 qts.
Al- 4 - 2
Pb- 9 - 3
Cu- 3 - 1
Fe- 40 - 16
cr- 1 - none
ni- 1 - ?
Mo- 91 - 60
mg- 15 - 12
B- 62 - 37
Na- 8 - none
Ca- 2410 - 3094
P- 712 - 757
Mn- 2 - 1
Zn- 820 - 868
K- 5 - none
Soot: 0% - 0
TBN: 5.18 - 6.31
