2005 buick lesabre blower motor
Gone Fishing
Blower motor stopped working on 2005 Buick Lesabre, i tested voltage at the plug wire to the motor and I have 6 volt on the low setting and 12 volts on the high setting. I'm not much knowledgeable on these things so looking for some guidance. Replace blower motor?
thanks for your help.
Yes, replace it. Most likely bearings ran dry and caused motor to overheat and burn a winding internally.
Here is Rock Auto listing of choices....you can also use these prices as reference for comparing buying locally.
Since this blower motor is located in the passenger compartment and you tested current at the ground, you probably can see what you need to do to replace it. But in case you need help, here is a video that shows more detail.
Good Luck, and let us know how it goes.
