- Joined
- Jun 2, 2003
- Messages
- 23,591
This is what the 2005 manual for the new Audi A4 (B7 platform) says about oil requirements:
- "The proper viscosity grade for your engine depends on climactic [sic -- nice Freudian translating, Audi!
] or seasonal conditions where you drive. You can use viscosity grade 5W-40 across all temperature ranges for normal driving conditions."
- 5W-30 or 0W-40 may be used as long as they meet VW 502.00, if 5W-40 is not available.
- "Only if the level of the oil is at or below the minimum mark on the oil dipstick - and no oil conforms to Audi oil standard VW 502.00 specifications is available - may you top off with a high quality engine oil, preferably synthetic-based, that meets ACEA A3, A5, B5, API SL or ILSAC GF-3 specifications, but even then only in the viscosity grades 5W-40. 5W-30, or 0W-40. However, between oil change intervals, never top off with more trhan 0.5 qt/liter engine oil that does not meet VW 502.00.
The manual also mentions that the car is equipped with an oil level sensor.
PS: There is no oil chart or ambient temperature/viscosity chart anymore.
