Hey guys,
I have a 2004 toyota solara with a 2.4l 2azfe engine and auto transmission with 180k miles. Recently, and this is happening more and more, after doing 55-65 mph on the highway, I exit the off ramp. Now when I'm merging with local traffic, if I press the accelerator I hear a grinding and the tranny shudders into the correct gear. Whenever this happens, I immediately let go of the accelerator and let the engine and tranny do its thing. This is an auto, and I can only describe it as the transmissions isn't engaged when going from 4-3-2-1 and when I press the accelerator its in between one of those gears and I hear the grinding because it's still shifting.
Now I've looked up used trannys "U241E" and they go for about 300-500 USD for a used one. I'm not sure if I should get my transmission rebuilt, replace with a used one, or get another car. Blue book is probably 1600 and I already have new tires and brakes. I want to know the cost of labor, if there's any remedies I can do in the meantime, and if the engine needs to be pulled to get it done. This is my daily so I'd like to keep it running, but if the labor to replace it costs more than the car, I'm better off getting rid it of it and letting the next owner know about it.
I'll be pulling the pan/changing the gasket, filter and fluids as well. Could be low on fluid, but I can never tell because the tranny dipstick is extremely inaccurate. I'll go with factory fill of 4 qts after I'm done. Filter could be clogged (low chance, most toyota mechanics claim to have never seen a clogged tranny filter??). If I find metal shavings etc. I'll know that's it..
I have also been changing the fluid every 10k for the past 30k. 150k is when I started. Not sure if PO ever changed it.
