2004 Subaru outback with automatic transmission and the California four-cylinder that has a whole bunch of extra oxygen sensors.
Car is running fine no issues and then wife was driving it and she said she lost power going to town and couldn’t go forward or reverse shut the car off then turned it on worked fine?
The E brake handle warning light popped on but that does not seem to be causing any issues ebrake still works and release as normal
I drove it to work the next day going down the highway it felt like it popped into neutral the car lost momentum going forward and I let off the gas pedal which drop down to idle while doing 70mph .
Every time I stepped on the gas pedal to try and continue driving the RPMs would rev up but it felt like it just dragged the car down in speed.
I coasted to the shoulder Check engine light was on . I tried driving forward then reverse and then back to forward. It just wouldn’t go engine was still running . I shut the car off for like three seconds turned it back on check engine light was gone and car worked fine.
