- Joined
- Oct 31, 2020
- Messages
- 3
Hi, first post here. Showing high silver in oil analysis this go around. Bought the truck last year, 3 oil changes since owning it. Rotella T the first time and Kirkland on this report. In between first and second report, I replaced Injectors and the 3 injector wiring harness in the valve cover spacer. Also flushed and changed coolant. I did not use any anti-seize when replacing injectors so not the source of the silver.
Runs okay as far as I can tell. No knocking sounds and no blowby. It does idle a little rough. MPG seems in line with what it should be, 15-16 city 18 hwy. No smoke at exhaust.
Any thoughts? Is it possible the silver is being leached from the electrical connectors?
