There are three pulleys, the tensioner, and the water pump that should ALWAYS be done when doing the timing belt. Rand is correct... you don't want a reused pulley blowing up 500 miles into your new belt and requiring a full rebuild... especially with only 43k. I would also do the thermostat and housing gasket at the same time as coolant since it couldn't be any easier (Subaru t-stat housings are on the bottom... just crack the housing bolts loose over a drain pan and you'll fully drain the system). Be sure to use the Subaru Coolant Conditioner and Subaru Green coolant is a good, safe bet. At this time in its life, new drive belts and hoses are wise too.
