2003 Pontiac Vibe 1.8l Base Model
Amsoil Series 2000 0w30
Dual remote filtration
OEM paper air filter
Unit: 93284 Kms
Oil: 11429 Kms 6857 miles
80%+ stop and go city driving
no make-up oil
Numbers on the right are from the virgin sample
Tin 0 0
Lead 2 0
Copper 0.2 0
Aluminum 3 0.9
Silicon 21 5
Iron 7 2
Chromium 0.5 0
Silver 0 0
Zinc 1250 1150
Magnesium 787 723
Nickel 0 0
Barium 0 0
Sodium 9 2
Calcium 2000+ 2300
Vanadium 0 0
Phosphorus 1100 1050
Molybdenum 0 0
Boron 19 60
Manganese 171 0
PHYSICAL PROPERTIES
Viscosity @ 100ºC 14.42 11.31
Water 0 0
Solids Glycol No No
Fuel Dilution No
OTHER PROPERTIES
Base No. 6.68 12.87
Oxidation 9.43
Nitro Compounds 0.00
Organic Nitrates 36.38
Oil Changed? No
Si and Vis jump out at me. They commented that I should change the oil and filter. What exactly does 14.42 Vis equate to in terms of oil grade? Wear, TBN and everything else looks good so should I really change it?
Unit: 93284 Kms
no make-up oil
Tin 0 0
Lead 2 0
Copper 0.2 0
Aluminum 3 0.9
Silicon 21 5
Iron 7 2
Chromium 0.5 0
Silver 0 0
Zinc 1250 1150
Magnesium 787 723
Nickel 0 0
Barium 0 0
Sodium 9 2
Calcium 2000+ 2300
Vanadium 0 0
Molybdenum 0 0
Boron 19 60
Manganese 171 0
PHYSICAL PROPERTIES
Water 0 0
Solids Glycol No No
Fuel Dilution No
OTHER PROPERTIES
Base No. 6.68 12.87
Oxidation 9.43
Oil Changed? No
