2003 Lexus GS430, Toyota Type-IV, 7,556 miles
Herndon, VA
This is the third transmission UOA I have done on this car.... Date: 7-28-04/10-28-04/9-14-05 Miles on Car: 10,002/15,007/37,682 Miles on Oil: 10,002/15,007/7,556 Oil Added: None/None/None Oil Used: Toyota Type-IV/Toyota Type-IV/Toyota Type-IV Oil was analyzed by Analysts, Inc. Most recent results on the right-most side. Iron: 11/17/18 Chromium: <1/<1/<1 Nickel: <1/<1/<1 Aluminum: 6/6/12 <----12 was underlined Lead: 2/12/8 Copper: 15/15/12 Tin: 2/<1/3 Silver: 0.1/<.1/<.1 Titanium: <1/<1/<1 Silicon: 45/42/26 Boron: 45/38/48 Sodium: 5/4/3 Potassium: <10/<10/<10 Molybdenum: <5/<5/<5 Phosphorus: 281/284/300 Zinc: 7/6/4 Calcium: 96/88/84 Barium: <10/<10/<10 Magnesium: 1/<1/<1 Antimony: <30/<30/<30 Vanadium: 2/<1/<1 Water, %VOL: <.10/<.10/<.10 Vis. [email protected]: 33.5/33.7/32.5 TAN: 1.40/1.46/1.40 Note that although the oil has been changed a couple of times, I can only get 2-3 quarts out each time, so the oil wasn't completely changed.... Comments? The lab noted the level of Aluminim in this most recent report, and stated, "Analysis reflects conditions/Values noted for monitoring purposes only. Other test results are satisfactory. Resample at the next scheduled interval". I'm not terribly worried about it, although I may take another sample sooner than I otherwise would [Perhaps late this fall]....Comments?
Elizabeth City NC
I am more familar with Honda/Acura transmission UOA'S but this one looks excellent to me. Hard to get much better in my opinion. You will get a long life from this transmission if you keep these changes up.
btanchors
Herndon, VA
benjamming, It has an internal strainer that can be replaced if you take the pan off. The pan has a drain plug, so I've been simply removing the drain plug to drain the fluid....Do you think the strainer needs to be replaced? According to the manual, a change is not needed before 100K miles...
Elizabeth City NC
I changed the screen on my Toyota Cressida at 190,000. It was as clean and the new one I installed. My guess is you will never need the replace the screen with regular service of the fluid.
