- Messages
- 1,383
- Location
- Agrestic, CA
Had to replace the transmission on the truck at 22K miles. Check engine light had come on, took it to the dealer and dealer said it had metal shavings in the pan. They replaced the transmission with a new transmission. Current transmission has about 150Mi of towing 1 motorcycle 200mi. Other then that mostly city and rush hour driving.
I flushed with Amsoil ATF after this UOA and will report in 10K.
code:Toyota Tundra 4.7L V-8 (2UZ-FE) Vehicle miles: 47,650 Transmission Miles: 25,064 Miles on oil: 25,064 Life of oil: 25 Months Lab: Blackstone “This is the first sample from the unit, and from what we can tell at first glance, it appears to be in good shape. Wear levels were fine for a wear-in sample and show no obvious problems. You can expect high wear at first, as new parts break in. Everything should drop next sample. The lead is from making compound used at the factory. You should not have any problems running the next oil a normal interval. Check back to monitor. Sorry to hear you had to have the transmission replaced!” Actual Universal Average Aluminum 7 14 Chromium 0 0 Iron 26 30 Copper 34 67 Lead 26 13 Tin 2 2 Moly 0 1 Nickel 0 0 Manganese 0 0 Silver 0 0 Titanium 0 0 Potassium 12 1 Boron 59 45 Silicon 23 18 Sodium 5 4 Calcium 81 536 Magnesium 7 29 Phosph 257 387 Zinc 25 264 Barium 3 3 Sub Viscosity @ 210 = 44.8 Should be 42-51 Flashpoint = 390 Should be >335 Water = 0.0 Should be <0.1 Insolubles = TR Should be <0.1
