2002 Silverado, 5.3 AMSOIL ATM 10w-30, 5,147 miles
Here is a sample from my 2002 Silverado. It has 182k on it and this run of AMSOIL ATM 10w-30 was run from Nov last year until last week with 5,147 miles on it. The oil filter was an Ea064 and the air filter is a Car Quest that was installed at the beginning of this oil change. Gas ran has been Exxon 93 with a mix of 50/50 E85 for the entire run.
I also had major gasket replacement done. The oil pan gasket, valve cover, intake and valley cover gasket were changed along with the rear main seal and the oil pressure switch. Reason was I had an oil leak and from the process of elimination the last thing I did was the rear main seal and of course that was the main cause. Oh well, it is all sealed up not.
I did have an oil consumption issue before the gasket changes. It would go through a quart in 5k miles. Now it doesn't use any. Also when ever I would tow our trailer, (4klbs 20') it would smoke on start up first thing the next morning. Now it is smoke free. So I'm thinking I had a small leak somewhere around my intake gasket/valley gasket.
