I was curious as to whether Lube Control really could make the cheapest "Manufacturer Approved" oil I could find last 10,000 miles.
The left-most analysis posted below was a nearly 10K run with Exxon Superflo SL 5W20 and Lube Control.
Take a look at my below results and let me know what your conclusion is.
The car is a 2002 Mercury Sable LS Premium with the 3.0 Liter 24V Duratec V6. Do not confuse that with the Vulcan engine of the same size available in this model.
Usage was 60/40 highway-city driving. Oil analysis by Schaeffer’s Manufacturing.
Schaeffers lab comment was, as it has been for the last two previous intervals, "CONTAMINATION AND ADDITIVE DEPLETIONS LEVELS NORMAL. MAINTAIN CURRENT OIL DRAIN INTERVAL."code:
Date 3/13/06 7/19/05 6/23/05 3/21/05
Lab Schaeffers in all cases
***Vehicle ID***
Make Mercury in all cases
Model Sable LS in all cases
Year 2002 2002 2002 2002
Engine Duratec 3.0L in all cases.
Miles on Vehicle 57454 47606 43170 38646
***Oil Identification***
Oil Brand Exxon Exxon Pennz Kendall
Oil Series Superfl Superfl Conv. Bulk Conv.
Oil SAE J300 5W20 5W20 5W20 5W30
API SX SL SL SL NR
Miles on Oil 9848 4435 4524 1946
Months In Service 7 4 2 2
***Elements***
Antimony Sb NR NR NR NR
Cadmium Cd NR NR NR NR
Vanadium V NR NR NR NR
Aluminum Al 6 5 6 7
Chromium Cr 0 0 0 0
Iron Fe 23 8 14 15
Copper Cu 6 5 5 3
Lead Pb 1 0 0 0
Tin Sn NR NR NR NR
Molybdenum Mo 128 259 218 33
Nickel NR NR NR NR
Manganese Mn NR NR NR NR
Silver Ag NR NR NR NR
Titanium Ti NR NR NR NR
Potassium K NR NR NR NR
Boron B NR NR NR NR
Silicon Si 16 17 17 12
Sodium Na NR NR NR NR
Calcium Ca 1262 2463 1997 2317
Magnesium Mg 5 11 7 10
Phosporus P 498 981 1014 924
Zinc Zn 619 1104 1027 1017
Barium Ba NR NR NR NR
***Viscosity***
cST @ 100 C 7.02 7.55 7.25 9.35
SUS @ 210 F NR NR NR NR
***Misc***
Flashpoint (F) NR NR NR NR
Fuel % N N N N
Antifreeze % 0 0 0 0
Water % 0 0 0 0.2
Insolubles % NR NR NR NR
Sulfur 7 6 8 5
Oxidation 10 3 2 0
Nitration 24 10 7 6
TBN NR NR NR NR
Ferrous Debris NR NR NR NR
Fuel Soot % NR NR NR NR
Additives LC LC LC None
