Passenger side of engine.Where is the ticking coming from? [area]
This is my vote. My 968 had a tick that was driving me crazy until I realized it got less as the car warmed up. Sounded like a lifter tick but it was an exhaust leak.Could be exhaust manifold leak.
I owned one of these exact trucks for 13 years. It sounds like mine always sounded. Not hearing a ticking.
Make sure the engine install brackets (bolted to the headers on each side) are either torqued down so they don't rattle or just take them off. If these become loose, they'll make a ringing sound in the engine bay.
And if you feel inclined to replace the PCV, determine if yours has the coolant-heated PCV before you buy one. Earlier years had the elbow PCV that installed into the passenger valve cover, newer ones relocate the PCV to under the throttle body and it accepts connections from nearby small-diameter coolant hoses. The PCV hoses themselves can deteriorate.
And finally if it throws P0171 codes, then your isolator bolts on the upper intake plenum need to be replaced with the redesigned Dorman one that is oil resistant. The job costs about $120 in materials but takes 4-6 hours to complete.
I wonder if the ticking noise is not a big deal and something simple is causing my cylinder 3 misfire. Or perhaps there is a mechanical issue affecting cyl 3 hence the noise and the misfire. Hard to tell.
I checked with a better scanner (Forscan) and it seems that I have three codes... P0303 (Cyl 3 Misfire), P0316 (Misfire on engine start), P2006 (IMRC stuck closed).
Could an IMRC issue cause a misfire? A noise? According to this video I just watched it can but there are probably different versions in different engines...?
^^^^^THIS!^^^^^Doesn’t sound good. I’d pull the valve cover to see if you have any loose rockers indicating a lifter or cam issue
