I’m going to suggest running your current oil (5w/10w-30…?) to ~ 6,000 miles.
Most of the public isn’t aware that there was a huge technology change in motor oils in the 1990’s with the move from Group I solvent based oils to Group II hydroprocessed based oils. These newer off-the-shelf (regular) Grp II oils are far superior to the old oils and are really more like synthetics over medium drain intervals (5000 -7500 miles) than they are like the old Grp I based oils.
A 6k mile change using regular oil versus a synthetic at only 7500 miles would unlikely produce any significant wear difference and engine cleanliness since your service (fair amount of miles in a short time) doesn’t look particularly severe. I even think 6k on a Grp II oil is being somewhat conservative given your service conditions. The rest of the car will likely fall apart before the engine does.
quote:
etrucker
Chevron research compares the performance of Chevron Delo 400 15w40, made from Group II base stock, with a 5W-40 synthetic oil; oil changes were made at 45,000 miles. It shows the mineral oil performs as well as or better than the synthetic oil in fuel economy, oil condition (including viscosity) and engine wear.
A synthetic will provide longer oil life, especially under severe conditions like trailer pulling or in high performance cars (turbo’s), but in an “average” engine like in your civic there shouldn’t really be any advantage to using synthetics with a medium drain interval these days. The average OCI on GM’s oil monitoring system is 8500 miles. This wouldn’t have been possible with the old Grp I based oils, and I would imagine GM went with a good safety margin even with those figures. I’ve seen several used oil analysis posted on regular oil run
well past 6k miles and they looked just fine.
Not saying don’t use synthetics -- as they provide a good extra safety margin and some people want that, but considering the cost you’d have to run them well past 7500 miles to get the cost/mile down to a regular motor oil. You could consider an 8-10k mile OCI with synthetics as they can easily perform very well at those intervals or more (given the type of service). If cost isn’t that much of a factor, a synthetic drain at ~ 7500 miles should produce excellent results (if you want to be on the conservative side of an OCI interval with synthetic). Here’s a recent
17,095 mile OCI on a synthetic.
12-13k miles on BMW 330I using synthetic.
9,211 miles Accord using regular oil.
PS. Don’t run a Grp II oil 45,000km’s like in that etrucker link -- that was in a diesel truck.
