Hey guys,
I have a 2000 Honda Accord (4 cylinder) with 395000 miles. I replaced the engine at 290000 with a used serviceable unit. It has done this for awhile and I cannot find the source...
It produces a noticeable burning rubber smell when climbing a significant hill at highway speeds. It's more noticeable with the windows down. All of the obvious stuff can be eliminated (belts rubbing on something, tires rubbing on something, etc). It's not being caused by any external friction source, and there are no oil leaks. I've even tried extending the exhaust exit past the bumper. There are no exhaust leaks. I've tried removing the valve cover vent from the air intake tube and venting it externally with a long hose that dumped about mid-chassis. I recently removed the dipstick and capped it off with a piece of rubber and a bolt (thinking that excess crankcase pressure was exiting past the loose fitting stick). I think that helped reduce the odor but it could be placebo. Any ideas?
-Travis
-Travis
