2000 Chevy PRIZM :plastic engine cover : o.k. to ?
usa
Plastic engine cover for PRIZM , COROLLA , MATRIX , and PONTIAC VIBE is it for looks ? Protection of wires , etc. ? Or both ? Would it be .o.k to remove the plastic engine cover off permanently ? Figure it could help the motor cool off a little easier ( theory is the plastic cover would hold / trap heat in between valve cover and platic cover due to less circulation of air , especially in stop and go driving ) .
Yes it's okay to leave it off. It's just there to dampen the noise of the fuel injectors and to keep new prospective buyers from being overwhelmed by the complexity of the modern engine. The cover also traps heat.
I'd leave it on. It protects the aluminum from the elements and may keep it from pitting.
Helps keep the coils dry too.
You know the insulation may cut down on the quick cooling of the motor and help keep water and crud from condensing on the valve cover.
I'm no engineer but there usually design follows function.
my .02 cents
I'm no engineer but usually design follows function.
my .02 cents
It is ok to take it off and leave it off. It is their because some people think looking at a platic cover is somehow more attractive then seeing the actual mechanical and elctrical componets of the engine! To me it would be like takeing a good looking curvy women and covering here in plastic panels that remove all curves from here form and make her apear to be a smooth squar box. Now bareing someone with a box fetish I am sure we can all see how silly this sounds. I guess people that do not understand or feel deeply for their car or truck would just as soon have the hood welded shut then have to be confronted with their own ignorance ever time they pop the hood.
Their is a lot to be said about the beaty of a well thought out mechanical design. No one ever says "Wow look at that plastic engine cover!!!".
Now some will tell you that some designs channel the air blaw blaw blaw.....This is rather silly for several reaons. The hood,engine splash protectors and space behind the engine between the engine and fire wall create the air flow that is needed for an engine. You want air to flow in the front through the grill through the raqdiator circle around the sides of the engine and over the top and then hit the fire wall and sink back towards the underside of the car. This is why it is bad to drive with hood off the car or to leave too little space between the firewall and engine.
