$20 Walmart soap canon for power washer – recommended
The Woods of NY
Hey Everyone! been super busy but I’m still here. Let me just start off and saying I’ve never owned a power washer soap canon so my expectations are not very high because I did not know what to expect.
I can report that this $20 soap cannon from Walmart is great. Even on the max soap setting it’s very frugal with the usage of your soap and suds up beautifully. It’s also adjustable tip to make the stream wider or jet like. it does everything it’s supposed to do with a decent size holding tank and works like a champ for the 20 bucks on a 3100 psi power washer. If you’re on the fence like I was I say go for it. Here is a picture a couple minutes after I was done spraying there’s still a ton of suds. Anyone else Rockin‘ a Soap canon?
Texas, USA
I looked for the one with the weirdest name on Amazon and bought it. 😄. This one is not at all frugal with the soap if you open it all the way up. I like a thick foam so it won't start drying in the breeze before I can hit it with the mitt and rinse.
