1) After you drain the coolant and fill with water ONLY, do you take the thermo out? Does this help with the "water flushing" aspect anymore than leaving it in?
2) I'm switching to a 70/30 mix. If my math is correct on a 12.6 gal system:
3.78 will be coolant
8.82 will be water
Can I round up on the coolant to 4 gals and top with water? Won't be as scientific as some would like, but will work... right?
8.82 will be water
