I just changed the oil on my Elantra for the first time. The Ford dealer I purchased it from claims to have used Motorcraft 5W-20 (which I know is a great oil) and a Motorcraft filter. I just hit 75k and that oil was in for ~3,250 miles, so I decided to change it. Well, I get under there and find a "TecSelect" T4612. I purchased a WIX 51334. Uh... these are two totally different sizes. The WIX is much larger in diameter. After triple checking, I decided I had the correct filter, and after some research the T4612 was somehow also correct (I think?). Well, now it explains why the dealer overfilled it by 1/4-1/3 of a quart
(I checked before buying, and ended up draining it myself the same day I bought it). Also worth noting, the entire OCI the engine sounded like complete
when cold, and would try to accelerate/torque up small hills at re-apply the gas and kick it into the proper gear otherwise it would eventually downshift 2 gears and rev up to ~3800rpm unnecessarily. I chalked it up to owning V8s my whole life and this is how newer 4 cylinder cars are. I constantly yelled at it saying "you don't have more torque just because you shack up next to a V8."
Well, in goes M1 AP 5W-20 (thanks VatoZone!) and the WIX and....
SILENCE! No more valvetrain noise, no more racket when cold, and even more strange... no more lugging up hills with low rpms. Even the gf said there was a big difference, so it's not just my imagination.
Can a filter really make that much difference? Was the TecSelect really that bad? Was it even the correct filter (does it restrict flow, have the same bypass settings, etc.)? I've heard of, but just never seen such a drastic change by a filter. I'm happy the engine is happy now, but now I'm wondering if any harm was done by using that filter. I'm really interested in what everyone's thoughts are.
