So kind of a weird situation I'd say. I have an oil leak on the 14 dart. I notice oil seepage build up on the driver side of the engine at the head gasket right near where the water outlet bolts to the engine. Then on the back of the engine at the corner on the passenger side the timing cover bolt is wet and so is the side of the block. It appears it's coming out of the head gasket area and slowly leaking down from there onto the timing cover area where it meets the blocks. I've noticed some oil consumption. The valve cover does appear to be seeping as well I replaced it at 31,000 but now at 70,000 here we are and one of the bolts in the center of the valve cover that has a grommet on it is full of oil. But the engine is clean from the valve cover until the oil leak below so I don't think it's coming from the valve cover itself. Anyone seen or heard of this issue? Thanks everyone!
